ā2025-02-02 01:59 AM
I often make 3D documents from 3D views, so I can add 2D annotation. No big deal -lots of success in the past.
Today, I created a 3D view of an object that measures 24" x 30" x 10". After creating the 3D doc, the first thing I do is measure the object, and the 24" side now measures 104'-7 3/4". What's going on? This is ArchiCAD 27.
Solved! Go to Solution.
ā2025-02-03 01:35 AM
If you save from a perspective window, it will not be to scale.
Save from an axonometric 3D view and it should be.
ā2025-02-02 09:02 PM
Can you post screenshots that show those measurements in 3D and in the 3D Document Viewpoint?
ā2025-02-02 11:17 PM
ā2025-02-02 11:18 PM
See video screenshot below. The ratio between starting size and 3D Doc size is different today!
ā2025-02-03 11:15 AM
Yeah, the measuring tool will show a random size for the perspective 3D Doc, but if you place a dimension on it, it should still show you the correct size.
