2020-10-01
04:33 PM
2023-05-09
01:25 PM
Gordana Radonic
2022-11-09 02:38 PM
Still an issue in AC26, just sayin'... (Transferring our company template from Archicad 23 to 26 when I encountered this. Great.)
2023-02-07 04:33 PM
Nothing helped me, except open each 3D view > right click on the current view in the navigator > "Get Current Window's Settings". This way every 3D view is kinda updated.
I know its a pain in the butt (i had around 30 3D view in my project), but i can't see any other solution (yet)
2023-03-31 06:19 PM
This bug just happened to me on M1 Max Macbook Pro running Archicad 26 for Apple Silicone. 3d View on the cover sheet of the drawings set is just showing white on the layout. It's there when open the window. I place a fresh copy of the 3d view on the coversheeet.. that one also just showed as blank white.
2023-04-18 12:27 PM
Same here on "normal Mac". Looks like a new bug after installing hotfix 3. Did you also install hotfix 3?
2023-05-19 08:04 PM
restarting your computer usually clears this up...
stupid tech tip "turn it off and back on again" actually works in this instance
2023-05-22 02:39 PM
no it's a serious persistent bug since hotfix 3, turning it on and off doesn't fix it.
2023-05-24 02:37 AM
24 May 2023
Can confirm, this happened on a colleague's PC just then.
solo PLN file, Windows 10, AC 25.
have advised her of the 3D document method.
tried to replicate it on my PC on a different file (teamwork), but the bug doesn't appear & the saved 3D View places OK in the layout.
#ForeverBug
2023-06-29 12:48 PM
HI All,
I also had this problem, then the weirdest thing happened:
-3D view is blank, I restarted the computer, cleared cache, sacrificed goats, nothing impressed my ArchiCAD
-I open the drawing manager, and find the drawing
-status = needs to be checked
-I double click on it, then I update it
-voila
I don't really understand why this worked, but I'm glad. I use AC26, the drawing was on archicad layer, full precision, original colours, etc.
hope it might help others 😉
2023-08-03 10:28 PM
I am having the same issue in ArchiCAD 25 teamwork. I did not know what was the issue.
For now the only solution that I found is to remove the background of the 3D instead to be white (255, 255, 255), I changed to (254, 254, 254), and this solve my problem. Know I have all the 3D views in the layouts.
2023-10-17 09:10 PM
Restarting Windows Explorer fixed it for me too!
