ā2025-07-08 12:34 AM
This is my first project in ArchiCAD 28 and when I publish my set of drawings, some of them are in full color and others are in black and white. All the view settings are the same with the same pen sets, graphic overrides, etc. so I can't figure out why they aren't publishing the same. When I look at the layouts on the screen they are all in color per the pen sets I selected. But when I publish the set to pdfs, some of the sheets are in black and white - see attached screen shots. Any insights are greatly appreciated! Thank you!
Operating system used: Mac Apple Silicon 14 Sonoma
Solved! Go to Solution.
ā2025-07-08 02:17 AM
In your publisher set, have a look at the 'document options' to see how the PDF will save.
You might have one set to colour and another to black & white.
Barry
Barry
ā2025-07-08 04:48 AM
Thank you so much Barry! I knew it was probably something easy and I just couldn't find the setting. Much appreciated!
