A19 Solo: Importing a master layout into another pln file
Dennis Hellyar
I am struggling to import a master layout file from one pln file to another. The organiser top left box does not have the browse option therefore the common TW solution doesn't work. Is this a limitation of Solo or is there a workaround please?
Dennis Hellyar
11 REPLIES 11
Erwin Edel
Yes, drag and drop places them as a drawing in the full version. You can turn layers on and off by opening the drawing settings.
I actually like it more than XREF as it doesn't bring all the attributes from the DWG in to your project.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Karl Griffith
As an update to this thread, ArchiCAD 20 Solo now has an abbreviated "External Content" menu to make the limited external content functionality a little more obvious and accessible in Solo.
It does not have all the functionality of the full version, but that is not expected (you pay less, you get less). All the same, it is a nice addition to Solo.
ArchiCAD 22
Win 10
