2006-07-28 01:16 AM - last edited on 2023-05-18 05:51 PM by Gordana Radonic
2006-08-18 07:53 PM
2006-08-18 08:35 PM
another Moderator
2006-08-18 10:39 PM
2006-08-20 02:03 AM
2006-08-20 03:53 AM
Don wrote:The 25% fill has changed in ArchiCAD 10. It is now an actual bitmap grey halftone instead of the vector dot pattern of years past. The vector pattern was for compatibility with plotters. I assume the change was to improve compatibility with printers. Perhaps it no longer works properly with HPGL.
I have had this problem also on a old (but still working) HP plotter. This is something new to AC10. Tried using a .plt file, but it still plotted the 25% wall fills to solid black. Is there a setting I am missing?
2006-08-20 02:36 PM
2006-08-21 12:55 AM
2006-08-21 11:03 AM
Don wrote:Ac10 tries to unify plotting and printing. This is quite appropriate, since pen plotters are more or less extinct these days. Many Print to raster plotters instead ofusing the old Plot command. In the process, they're getting rid of the old bitmapped fill patterns that slowed down printing. I.e., a 25% fill should be a gray tone with 25% black and 75% white. This is normally accomplished by sending a gray solid fill to the printer/plotter and let it rasterize itself, optimised for the unit in use.
Ok, I tried all the combinations of pens that I could think of and the only thing that allowed me to plot 25, 50 and 75% (12.5% does work) was to use the grey scale plot setting (as opposed to black and white or color), but then all the colored lines printed not solid but dots.
Any other thoughts? This must be a problem others are having who plot and not print. BTW, saving as a plot file didn't help either.
2006-08-21 04:33 PM
