Got a minute? We appreciate your feedback:
Graphisoft Learn survey
AC 21 lines display issue
Working with AC21 no matter what color line, fill, library part I select and place, they all show in blue color.
It does not matter what color pen I select
Also, the "True line weight" has no effect on the lines placed in the drawing.
All the lines placed are "Drafting Line" type
This happens only in the Project Map and the View Map but it works properly in the Layout Book view
Any ideas what setting I am overlooking?
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
3 REPLIES 3
Graphic Overrides?
Thanks Barry.
I will need to work on this.
I have not done any customize on AC21 so I cannot explain why this is happening.
Any way to find a quick "RESET" or "DEFAULT" ?
If it is graphic overrides then there should be a "No Overrides" GO combination.
Or maybe it could be Renovation Filters in which case there should be a "Show All" renovation filter.
