2021-01-15
06:20 PM
2023-05-22
11:51 PM
Gordana Radonic
2021-01-18 03:38 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-01-18 10:08 PM
mnguyen wrote:Per your request.
Thank you very much for the report and I am very sorry about the issue!
From my experience, the issue is usually caused by walls are not 100% parallel to each other. One way to check is to set the 4 digit for measuring angle in the Dimension style, then use the Angle dimension tool to measure the angle between the 2 walls. If there is a small deviation, we will see something like 179.9999 or 0.0001 degree. If that's the case, we must manually reset each wall in the project.
Please let me know if it helps with the issue!
Best regards,
Minh
2021-01-20 03:29 PM
Minh Nguyen
GRAPHISOFT
2021-01-21 07:26 AM
2021-01-21 05:15 PM
mnguyen wrote:
Thank you very much for your answer!
Would it be possible for you to share the file with is for a closer look?
A video of how to reproduce the issue would extremely helpful also!
Please let me know if you need a secure place to upload the file.
Thank you very much for your help! Looking forward to hearing from you!
Best regards,
Minh
2021-01-21 05:16 PM
Richard wrote:Thank you Richard for the suggestion. I shall have a look for the item.
Look for the "Element Orientation Check" label on BIMcomponents.com. This is the fastest way to check to make sure elements are orthogonal.
