2015-07-18 03:18 AM - last edited on 2023-05-23 03:09 AM by Gordana Radonic
2015-07-18 03:48 AM
2015-07-18 02:26 PM
Dave wrote:There is a new command Label Selected Elements. If all the Windows are to be labeled, after modifying the Label settings, change to the Window Tool, Select All Windows, then Label Selected Elements. If the selection is more complicated, use Find & Select.
Then place by clicking each window and door in each elevation. Pretty tedious. There must be an easier way to "turn on" markers in a more global manner. But maybe not. Progress.
2015-07-18 05:45 PM
David wrote:Very good--thank you, David. For anyone else searching for this, the command can be found at Document-->Document Extras.
2015-07-23 10:36 PM
2015-07-24 12:41 AM
2015-07-24 06:09 AM
2015-08-04 12:46 AM
