Dave Jochum
AC19--Door/Window Markers in Elevation
Who's figured out how to display these in elevation with the "improved" AC19 label implementation? The option to "Label Window" no longer exists and the "Listings and Labeling" pane is gone from the Settings window.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
7 Replies 7
Dave Jochum
Figured it out...I guess. In each elevation, choose the Label Tool. Select Identification Label 19. Choose "Associative" as label type. Set the various parameters as desired (including eliminating the "Pointer"). Then place by clicking each window and door in each elevation. Pretty tedious. There must be an easier way to "turn on" markers in a more global manner. But maybe not. Progress.
Dave Jochum
David Maudlin
There is a new command Label Selected Elements. If all the Windows are to be labeled, after modifying the Label settings, change to the Window Tool, Select All Windows, then Label Selected Elements. If the selection is more complicated, use Find & Select.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dave Jochum
Very good--thank you, David. For anyone else searching for this, the command can be found at Document-->Document Extras.
Dave
Dave Jochum
I don't have the Label Selected Elements in mine!
I cannot get a screen shot & photo of screen is too large to print, but when I open Document> Document extras it is the same as 18 with no "Label Selected Elements as in the screen shots etc
You have probably migrated your Work Environment from AC18 to AC19 and AC18 didn't have this command.
Go to the Work Environment and manually add this command to the menu.
Thanks Laszlo
aahatimo
Does it easily label doors and windows properly and in the right orientation now? I hope!
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
