Johan Stinckens
AC21 - Pen color in Layout different to Master Layout
I am experiencing some strange behaviour with layouts in AC-21.
I've created a master layout on which a view from the project info is placed. On this master layout pen color/weight is correct -> black lines / green logo-part.
When I create a layouts which uses this master-layout, suddenly everything from the master layout is shown in RED, regardless of its original color.
I've checked the pen set for the master layout, the layout, the layout book. All are set to Basis Zwart (= standard black).
Any ideas?
Johan Stinckens
BIM Modeller at Atrium Architecten
Archicad user since April 2014 (v17 - v29) - CC iRT i9-12900 - 64 GB / Nvidia Geforce RTX 3080 - Windows 11 Pro 64
Other than that it's hiking, camping, climbing.
1 Solution
It is an option in the Work Environment > On Screen Options.
The idea is that being a different colour it differentiates what is on the master and what is on the layout - because the master is not editable from the layout.
If you don't have this option on you may find you start wondering why you can't edit parts of your layout.
Go to post
7 Replies 7
Johan Stinckens
Thanks Barry!
I had been searching for a setting in the MVO etc, but not in the Work Environment.
Johan Stinckens
Eduardo Rolon
FYI,
Even if they are Red they will print correctly.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I'm currently having a similar issue with AC20. I've posted for the first time to try and resolve it. Please forgive me if I'm messing up at all.
When I capture things from the Project Map, they're in color. Same in the View Map.
As soon as I place them on a Layout, they're in black and white.
Any help would be greatly appreciated.
David Maudlin
Mitchell:
If you are placing Drawings (using the Drawing Tool) on Layouts, then open the Drawing Settings and look at Size And Appearance > Colors:, and also check Pen Set: (the Pen Set could be all black).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Stress Co_
ejrolon wrote:
FYI,
Glad to see you're back Eduardo.
I hope you weathered the storms OK.
Marc Corney, Architect
Red Canoe Architecture, P. A.
David wrote:
Mitchell:
David
That was a huge help David, thank you so much. The change from AC19 to AC20 has really thrown me and as a result I've hesitated to move on to 21 before the end of the semester.
Updated the signature, hope its up to scratch.
Thanks again.
