joimagg
AC24 3D Document bug?
Hey, does 3D document have a bug in the latest AC24, that it doesnt show windows and doors when the 3d document view has been added on a layout?
Se atteched images, windows show in AC23 but not in AC24.
2 Replies 2
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you very much for your report and I am very sorry about the issue!
Unfortunately, I was unable to reproduce the same problem as you mentioned, using Archicad 24 INT 4018. First, I would like to make sure that the latest update build is installed (currently 4018 for Archicad 24). Furthermore, please let me know which language version you are using since probably it could be a library bug.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
joimagg
Hi, the problem was fixed by uninstalling all previous versions of Archicad...somehow that helped??? hehe
