Scott Bulmer
AC25 stair shows in 3D window but not in section view
Greetings, I am having an issue in AC25 V 4013 using Mac OS 10.15.7 with stairs.  I have tried the settings noted in a prior posted solution however nothing is working.  Basically the stair can be selected in section but is not visible.  It is visible in the 3D window.  It should be noted that it has also disappeared in plan view, however I reconstructed it and now it is visible again in plan & 3D views, just not in section.   Please see the attached screenshots.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
13 Replies 13
Scott Bulmer
Thank you Barry.  Mod file attached.
OK, I can see what the problem is.
The stair it self is set to show on all relevant reno filters.
However the components of the stair (flight, landing, finishes) are set to show on only one particular filter.
It seems you can't just change this option in the stair settings.
But open the Renovation palette.
Toggle the show on filter button on and off again and that seems to reset the filter for the sub elements.
I am not sure how the stair and the sub-elements got different filter settings in the first place though.
Scott Bulmer
Hey Barry, you nailed it.  Thank you so much for your knowledge and generosity in giving of your time.  Truly amazing trouble shooting skills~!~  The placed plan view/drawing is working correctly as well.    Scott
I just had the same problem again and tried the solution I described before.
It didn't work.
But simply changing the renovation status did.
So select the stair, open the renovation palette, press a few buttons to change the renovation status, and then set back as you actually want it.
Or just change the renovation status of the stair (you can't change the tread or riser status) in the stair settings to something different and then change it back to the status you want.
