‎2004-10-01
01:23 AM
‎2023-05-19
04:07 PM
Gordana Radonic
‎2004-10-01 05:48 AM
‎2004-10-01 08:42 AM
Thompson, wrote:If you double click on a Master, you see only the Master contents. Not what you placed on the Layout that uses that Master. So whatever you need to show on all the sheets of your set, put it on the Master. Tip: ypou can copy&paste from one Master to another, multpily the Masters by copying them and pasting into the Master navigator.
Just installed AC9 and was playing around in Plotmaker. I found you can move Master Layouts in the Navigator (re-ordering them). However when you move them the program erases all placed objects (text, lines, etc.) on the layout you move, and Undo does not undo that.
‎2004-10-01 02:54 PM
‎2004-10-01 08:49 PM
‎2004-10-04 05:54 PM
Thompson, wrote:Alex,
Just installed AC9 and was playing around in Plotmaker. I found you can move Master Layouts in the Navigator (re-ordering them). However when you move them the program erases all placed objects (text, lines, etc.) on the layout you move, and Undo does not undo that....
