Acrobat Pro settings for PDF Publisher set
Jefferson
I am working with the demo version of Acrobat Pro 8, trying to dial it in and make it work for me before shelling out, wondering how those of you who use this for your publishing of PDF sets have it setup. After having some oversize file issues,
http://archicad-talk.graphisoft.com/viewtopic.php?t=18310
I am already much happier with the reduced file size output vs. the built-in Amyuni PDF publisher, but, can't figure out how to merge multiple sheets into a single PDF set straight out of ArchiCAD. Can this be done, or does it always require post merging process in Acrobat?
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
16 REPLIES 16
I don't use the publisher but, get the results you want from setting the printer setup to the adobe printer with proper page size selected.
I have my printer set up as Adobe with page size set to the layout page size. I then choose all layouts in navigator I want printed and hit the print button under the file menu. I then choose the options to print all "selected layouts". I name the file and thats it. I get a complete set of the pages selected in one PDF file.
Sincerely,
Jefferson
Hey Barry & Mark -
I think you two are essentially saying the same thing.........conceptually anyway, and, I like the outside the box thinking
In trying your method, [typically I don't use the navigator palette anymore, Organizer seems to do it for me, but I digress, again.......] My problem is, if I am trying this correctly, I select the drawings I want to merge into a single file in Navigator, viewing at least one of them, [is that right?], and when I go to file>print I loose the multiple selection. I am only allowed to print a single file.........can you help point me in the right direction?
might be some lag time in my responses here, trying to cook dinner at the same time..........
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
__archiben
Jefferson wrote:
... when I go to file>print I loose the multiple selection. I am only allowed to print a single file.........can you help point me in the right direction?
you need to be in a layout window to get the option to print multiple layouts in the print settings dialogue. but yes - that works. the process disappeared on me for a while - it popped up in acrobat about 5 minutes later - so i thought that it had failed. and i don't get an option to merge the layouts this way, it just merges them whether i like it or not.
nice workaround!
cheers
ben
b e n _ f r o s t
Jefferson wrote:
Hey Barry & Mark -
Yes.
The organizer will work so long as you don't have the navigator open as well - just one or the other.
Yes, I forgot to say you must be viewing a layout otherwise you will print what is on the screen in Archicad.
The layouts should remain selected in the Navigator/Organizer - maybe not highlighted but they should still have a box around them.
You will only be prompted for one file name and it should add all pages into that one file so long as you choose to print "Selected layouts in Navigator".
Jefferson
That's it!!! That's it!!! Thanks so much gents! I figured there had to be a way and someone would've been here before..........excellent work-around!
I was in the layout but glazing right over the old style "drawings selected in Navigator".
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
But, you only get hyperlinked markers with the method that Erika gave, using the Amyuni driver, right? So, we don't want GS to think this workaround resolves the issue?
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Jefferson
Absolutely right Karl! this does not constitute a perfect solution. I never actually knew that the section markers in my PDFs were hyperlinked... Live and learn!
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
