		2007-11-12
		08:12 PM
		2023-05-19
		10:21 PM
			Gordana Radonic
2007-11-14 02:43 AM
2007-11-14 03:11 AM
 2007-11-14 03:33 AM
Jefferson wrote:you need to be in a layout window to get the option to print multiple layouts in the print settings dialogue. but yes - that works. the process disappeared on me for a while - it popped up in acrobat about 5 minutes later - so i thought that it had failed. and i don't get an option to merge the layouts this way, it just merges them whether i like it or not.
... when I go to file>print I loose the multiple selection. I am only allowed to print a single file.........can you help point me in the right direction?
2007-11-14 04:04 AM
Jefferson wrote:Yes.
Hey Barry & Mark -
I think you two are essentially saying the same thing.........conceptually anyway, and, Ilikethe outside the box thinking
Jefferson wrote:The organizer will work so long as you don't have the navigator open as well - just one or the other.
In trying your method, [typically I don't use the navigator palette anymore, Organizer seems to do it for me, but I digress, again.......]
Jefferson wrote:Yes, I forgot to say you must be viewing a layout otherwise you will print what is on the screen in Archicad.
I select the drawings I want to merge into a single file in Navigator, viewing at least one of them, [is that right?],
Jefferson wrote:The layouts should remain selected in the Navigator/Organizer - maybe not highlighted but they should still have a box around them.
and when I go to file>print I loose the multiple selection. I am only allowed to print a single file.........can you help point me in the right direction?
2007-11-14 05:48 AM
2007-11-14 06:02 AM
2007-11-14 06:15 PM
But, you only get hyperlinked markers with the method that Erika gave, using the Amyuni driver, right? So, we don't want GS to think this workaround resolves the issue?Absolutely right Karl! this does not constitute a perfect solution. I never actually knew that the section markers in my PDFs were hyperlinked...
 Live and learn!
  Live and learn!
