All fills from sections turn white on layout
The file was working perfectly fine, fills intact, until sometime yesterday when all my fills disappeared in my layouts. The view map fill is still perfect. I thought at first they were completely gone in layout view, but by turning the transparency on and off (thought I might have done so accidentally) I can still see the hatching in a transparent white/grey. I've tried changing the colors, double check my renovation filter, checked both my model view options and set my graphic overrides to 'no overrides.' When I publish my sets to PDF the hatch is still missing, (white). This is happening in all the layouts with fill. I'm at a loss.
10 REPLIES 10
dhnguyen
I also have the exact same problem, has any of you been able to solve it yet?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
