Anotation objects in renovation filter
I am having a trouble with an annotation objects (fils lines) in Renovation filters demolition and New. In Project and View map are displaying fine but in Layout they are shown as existing grey.
Did eny of you had this kind of problem? Thanks for any help.
BR
2 Replies 2
this is problematic View - Layout View.
I see you are using Archicad 21.
Do you have the latest update installed (build 8002)?
There have been posts about layout/renovation filter problems, but this was with newer versions.
Archicad 21 is no longer supported (updated) so if you have the latest update there may be no solution.
You could try the 'Open & Repair' option to see if that fixes the file.
Make sure the view that you have used for the drawing you placed on the layout, has the correct renovation filter set.
Easy way to check is select drawing on the layout, right click and 'Open Source View'.
If it looks the same then the view has the wrong filter set.
If it opens correctly then that may be a problem that can't be solved (if you are using the latest updated - build 8002).
