2024-11-04
01:18 PM
- last edited
Wednesday
Gordana Radonic
Archicad inserts numbers in the left corner in white. This is the inscription "GSPPublisherVersion 0410098".It can't be removed and it is made in white. So if I need a regular drawing in PDF it is not visible because it blends in with the white background in PDF, but if I need to replace the background in the drawing with anything other than white, this inscription stands out, which is very annoying. If I crop the layout, the inscription simply shifts, that is, it is always visible. Does anyone know how to solve this problem?
Operating system used: Windows 25
2024-11-05 02:06 AM
Do you have a commercial or educational license?
If it is moving with the frame when you crop, is it a drawing title that could be turned off in the drawing settings?
2024-11-05 11:04 AM
I have a commercial license. It was also in my educational license when I had it.
it moves with the frame when I crop the layout, it is always the lower left corner, it is not a title, even if I save a blank pdf without a drawing in it, this signature is in the PDF. I think this text appears in everyone's license, it is just not visible because the inscription is white and maybe few people use a different background in the PDF... I just transfer the PDF file to Photoshop and use a different background color there, and this inscription is visible.
I also tried using an empty archicad file/another versions and it happened there too. the only way out is to crop the pdf in third-party services....
2024-11-05 11:14 AM
2024-11-05 12:41 PM
If the file was created in the educational version, it will always contain the educational watermark.
Even if you open it in a commercial version.
Once and educational file, it will always be an educational file.
Files created in the commercial version will not have this watermark.
2024-11-05 12:56 PM
yes, i understand that. But at the moment i have a commercial license to work and when i open a new file i still get this text on the left corner.
2024-11-05 02:48 PM
It should not happen on a new file unless that new file is based on an old educational file or template.
A new file based on the commercial template should not have this.
When you save the file it should have a .PLN file extension.
I think the educational files have a .PNE file extension? (I am not sure)
2024-11-11 02:15 PM
Hi Barry Kelly,
extension for educational files is also .PLN.
