I have some additional thoughts that may prove helpful. It appears that some of the dimensions that were associated to the center hotspot of doors and windows are the ones that have been moved or deleted by AC10. I do recall that a number of the doors' IDs had been changed recently. Our door and window markers, as well as our door and window schedules, read from the door / window's ID, so the door IDs were changed to update our schedules. Our window IDs were not changed because they were OK. So now it looks as though the dimensions have been re-associated to different doors (mostly) or windows all over the project.
For instance, a dimension that used to associate to a grid line and a door centerline now associates to the same grid line and now a different door somewhere else in the project (though sometimes it's to the center of the different door or sometimes to the edge of the door opening).
However
, this is not always the case. Sometimes, and less often, a dimension will associate to one correct, original point and then bypass any window or door opening entirely and associate to a wall edge or to the corner of a fill. Those walls and fills did not change. Of course, this sort of thing also happened to some windows whose IDs were not changed. And, it happens to one window in a string, but not the one next to it.
Even more exciting, the problem seems to be getting worse. I'm attaching two more images from two different dates, after the dimension fun, that show the dimensions de-associating from some windows in a wall.
In the first image, the dimension string that runs from top to bottom over the top of the stairs first reads properly, dimensioning the centers of the windows 114-3, 114-4, 114-5, and 115-1. The dimensions have already been weirdified (a technical term), as can be seen from the dimension line than cuts over the top of the 01/513 detail tag.
In the second image, the dimension string has de-associated itself from all the windows except 115-1. None of the window IDs had been changed.
I can see that over 500 people have viewed this thread, and only 3 comments. PLEASE share your ideas or say if this has happened to you! Is it a setting or an option? An improper technique for placing the dimensions (i.e., different than how the manual says to place them)? A known bug? A haywire parameter? A plug-in? CadImage has been removed recently.
Please help!
Zolli
