We value your input!
Archicad 19 layout publish formats missing
When trying to publish layouts the only available options are pdf and BIMx Hyper model, but I need DWG.
Anyone has any idea what´s wrong?
Karl Griffith
I had a similar problem a while ago. It was resolved with the following thread:
https://archicad-talk.graphisoft.com/viewtopic.php?f=12&t=58068&p=273577&hilit=dwg+export#p273577
ArchiCAD 22
Win 10
Thanks for the answer, so I identified that the problem is the third option from the thread(migrated Work Environment), but not quite sure how to add those commands manually(through Work Environment customization ) to the format selection menu.
