2026-03-11 04:53 PM
As stated, in the Organizer we are unable to export a PDF as PDF/A when grouping several folders/files in to one file.
If we export only one sheet it works as expected.
I've double checked if the Document options are selected to export as PDF/A
This type of standard is required to digitally sign the PDF files.
We switched from from AC27 to 29 and in the previous version we didn't had problems.
2 weeks ago
Because a single sheet exports as PDF/A and the same grouped set worked in AC27, this looks more like an AC29 Publisher regression than a general PDF/A setting issue. I would test a new Publisher Set with only two simple layouts, saved to a short local path, using the same PDF/A settings.
If that still fails, I’d publish the sheets individually as PDF/A, merge them with a PDF/A-aware tool, and validate the final file before signing it. I’d also send that small two-layout test file to Graphisoft Support, since it gives them a reproducible AC27/AC29 comparison.
If a PLT-based PDF/A workflow is also useful to you, full disclosure: I’m working on PlotPDFPro. For Archicad, the supported route is PLT → PlotPDFPro → scale-preserving PDF/A. It doesn’t replace troubleshooting the AC29 Publisher regression, so I’d still try to resolve that first.
