2023-05-18
02:29 PM
2023-05-18
05:21 PM
Gordana Radonic
Greetings, AC Community.
This topic was previously discussed but I believe no solution was given back then. I've been dealing with this issue, whenever I try to move the content inside a bounding box, Archicad crashes.
Sharing the bugID below:
AC25-2023-05-17-15-30-05-1450
Regards,
Andre
macOS Monterey 12.6.3 | Intel UHD Graphics 1536MB | 64 GB MHz DDR4 RAM | Archicad 25 (6000)
2023-05-19 08:33 PM
Is anyone facing something similar?
2023-05-19 11:42 PM - edited 2023-05-19 11:43 PM
You say this has been previously discussed, but I have never seen this topic raised. Perhaps you can give a link to the prior discussion?
Do I understand correctly that you have placed a drawing, and optionally changed the clipping polygon on the layout sheet - and that then when you move the drawing inside the clipping polygon Archicad crashes with Archicad 25 build 6000? What localization/language version?
Copying a bugID here accomplishes little. The bug ID is only useful to technical support, and this is a user forum. Did you contact technical support with your bug ID?
2023-05-23 12:13 PM
Hi Karl,
Thanks for your reply.
Before sharing this problem with the community, I've seen this (or a similar) topic. Please see the link below:
Correct, Archicad crashes whenever I try to move the drawing inside the clipping polygon. I'm currently with Archicad 25 build 6000 USA FULL.
I ended up sharing the bugID since it's often requested when reporting a crash. Sorry for that. And no, I haven't yet contacted technical support, only sent it via the bug report pop-up window after each crash.
Thanks,
AP
macOS Monterey 12.6.3 | Intel UHD Graphics 1536MB | 64 GB MHz DDR4 RAM | Archicad 25 (6000 USA FULL)
2023-06-05 11:16 PM
Following up on this topic...
2023-06-06 02:28 AM
It seems others can not replicate the problem.
Have you contacted you local support and asked them to follow up on that bug ID?
