2022-06-14 03:21 PM
Can I write on plan the door stamp by story, for example door 1 - story1 ,2 or 3... I checked everything and didnt found the answers 😞
Solved! Go to Solution.
2022-06-15 03:30 AM
I think what you're asking is to create a new GDL.
with home_story and n = REQUEST("Home_story", "", index, story_name)
It seems possible to create a new GDL Label.
2022-06-15 02:28 PM
You can create property that will combine door ID and storey number or storey name:
CONCAT ( {Property:General Parameters/Element ID}; "-"; STR ( {Property:General Parameters/Home Story Number}; 0 ) )
2022-06-15 03:30 AM
2022-06-15 12:41 PM
thanks, it helps me to understand what i have to do, but also it takes many time to custume label for door or is there any other whay to do it inside door stamp marker from classification and properties ? see attached photo
2022-06-15 01:43 PM
I don't use it.
However, I study what I need and use it after modifying it.
And I've never tried to put a level into a door or window. Because it is fully expressed in the schedule.
2022-06-15 02:28 PM
2022-06-16 08:53 AM
Thanks it works now, I needed this numbers on plans in door ID and according them are all door shchedules.
2022-06-16 09:34 AM
2022-06-16 12:24 PM
Congratulations on finding the answer. ^^
2022-06-16 02:06 PM
thanks, CONCAT ( SPLIT ( STR ( {Property:General Parameters/Home Story Number} ), ".", 1 ), "/", STR ( {Property:General Parameters/Element ID} ) ) this is exact answer what i was looking for 👌
