AutoText not working
Laura Yanoviak
Instead of the following:
1560 Broadway, Denver CO 80202
This string is displayed in all Master Layouts:
<STREET>, <CITY> <COUNTRY> <CODE>
We've never had this problem before, but now it is consistently happening on different machines and all new PM files. I've tried deleting/retyping the necessary text into the Layout Book Info box. I even cut/paste this text string from a "working" PM file into a new file, but still no luck. All other AutoText entities are working fine.
In a hurry, no time to post screen shot -- any ideas? LJY
7 REPLIES 7
Aaron Bourgoin
Does the code not require something to say where this data is coming from?
Look at the Autotext codes inserted on a section marker in ArchiCAD - They start with PmA. Try that and you should get what you want.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
David Maudlin
Laura:
Has this information been filled in under Book>Book Info... ? Just a guess.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Laura Yanoviak
Yes it has.
Well... came in this morning and now all is as it should be (I had tried a cold reboot yesterday as part of my attempts to remedy the situation, and this too did not help). All I have gleamed from this is it had something to do with more than one AutoText entity in a single line of text. Thanks for the help, LJY.
TomWaltz
The autotext codes in section and detail markers are fake. They have no actual bearing on what Plotmaker does. I abbreviated our custom markers to <DR> and <SHT> so they did not look so obnoxious.
Thanks to Mr Lohden for that little trivia....
Tom Waltz
I have a similar problem where the Autotext label is not displaying the object ID. It worked fine previously on the same project.
I suspect that the Label was not placed with the "Associative" Geometry Method, so it is a static Label.
However, you can select any static Label and CTRL-click on any element and the Label will become associated to that Element, and display the Element ID properly.
Worked like a charm, thank you very much.
