2015-01-1511:32 AM - last edited on 2023-05-2211:57 PM by Gordana Radonic
2015-01-1511:32 AM
Hello!
I am working in ArchCAD 16 and the problem is that i have the wall with windows, but I am not able to put out dimensions in any good manner.
If I move the windows around after , the dimensions stay in the same place and are not connected with the window. Then i have to delete them and make a new dimension line
Cant get the dimension function to link with window object neither manually nor with Auto dimension tool.
I did read both of these instructions and checked the settings to have the 2D Hotspots enabled, but it still doesn't work.
