Automatic dimensioning
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-06-07 07:22 PM
My walls have different thicknesses and brick columns in some.corners. this is what came out when I used the automatic dimensioning tool.
Not.perfect. wall thickness missing. Picking up points at the far end. Any tips?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-06-08 11:58 AM
Make sure everything is properly defined as core.
In my experience the automatic tool takes much longer to correct than placing each dimension manually.
AC 10-26 INT/GER/FR on Win 10/ Win 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-06-08 02:48 PM - edited 2023-06-08 02:52 PM
Check if the angles of the placed walls are orthogonal.
https://bimcomponents.com/GSM/Details/24687
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-06-09 07:07 AM
It is an existing building so walls are not quite straight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-06-09 07:29 AM
If the walls are not all at perfect right angle to each other and the wall is not perpendicular to the dimension line, it will not dimension the wall thickness as you have discovered.
The same will happen if you manually click the wall thickness to dimension it.
If the wall is not perpendicular to the dimension line, it will not dimension.
You have to manually dimension the exact nodes that you want.
