Axonometric view scale
Hi guys!
Can you help me? I have some trouble with the scale of axonometric view.
I want to print a top-view at scale but it's seems impossible.
How can i put on scale to layout a general axonometric view.
Thank you!
4 REPLIES 4
Erwin Edel
Did you save your view as 3d document?
3d documents work the same way as elevations and sections for the most part. Dimensioning can be a bit tricky sometimes, but scale works the same as any other view.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
I want to put on a layout. Is it possible somehow or I need to save separately than import to layout?
You don't say what version of Archicad you are using - you should add this to your signature in your profile (link at top of this forum).
In 18 you can right click in your floor plan and save as a 3D Document.
Then create a view in the View map of this 3D Documents that saves the scale, layers, pens set, Model view Options, etc.
Now you can add this to your layouts - just like you do for any other views.
The scale (and other settings) will be remembered at all times.
Sorry for the incomplete profile, I was in hurry.
Thank you for help, I'm actually using ArchiCad 18.
