2022-11-28 10:02 PM
I am currently trying to publish some mod files to our BIMcloud. Everytime I set the path and folder, i then go to hit publish. Once i hit publish, it continues to tell me to set the path, which is already set. Its as if it is not recognizing that a path is set. See the image for what pops up when I hit publish.
Its frustrating, because the address/path is already set.
Any suggestions or help on this issue would be greatly appreciated.
Thanks
Solved! Go to Solution.
12 hours ago
Well, in my case, I eventually found a solution <here>. Apparently, the problem was a special character “ | ” (vertical bar) in the publisher set's name. I recreated the set, with a different name, and then the publisher worked just fine!
2022-11-29 09:43 PM
Is the Palette reserved? Or the items you wish to modify, are they reserved?
Do you have a Role that allows you to modify Publishing Sets?
2022-11-30 01:45 PM
Yes, everything is reserved and I have no limitations to my Archicad project role wise.
Just seems to continually not recognize that a path is already set.
2022-11-30 02:01 PM
Im now noticing in Arch 26, it is allowing me to publish to "My publisher sets" but not "Public Publisher sets"
2024-03-18 01:22 AM
Hi, I'm using Archicad 27 and I have exactly the same issue when I try to publish to a BIMcloud folder or project. Any clue?
3 weeks ago
Hi, may i know if this issue has been resolved?
12 hours ago
