BIMcloud wont publish
ArchDexel
I am currently trying to publish some mod files to our BIMcloud.  Everytime I set the path and folder, i then go to hit publish.  Once i hit publish, it continues to tell me to set the path, which is already set.  Its as if it is not recognizing that a path is set.  See the image for what pops up when I hit publish.
Its frustrating, because the address/path is already set.
Any suggestions or help on this issue would be greatly appreciated.
Thanks
4 REPLIES 4
Is the Palette reserved? Or the items you wish to modify, are they reserved?
Do you have a Role that allows you to modify Publishing Sets?
Yes, everything is reserved and I have no limitations to my Archicad project role wise.
Just seems to continually not recognize that a path is already set.
Im now noticing in Arch 26, it is allowing me to publish to "My publisher sets" but not "Public Publisher sets"
Felipe Barradas
Hi, I'm using Archicad 27 and I have exactly the same issue when I try to publish to a BIMcloud folder or project. Any clue?
