BUBBLE CORRECTIONS?
HI, I JUST GOT PLANS BACK FROM PLAN CHECK....HOW DO I BUBBLE THE CORRECTIONS WITH THE LINE TOOL, IF THE BUBBLE IS TOO BIG IN SCALE TO THE DRAWING? IS THERE ANOTHER TOOL?
3 Replies 3
Naddlles
You can change the scale of your bubble line type (or better still, make a duplicate and change that, then assign it) in Options> Element Attributes> Line Types.
HTH
You might also consider using the spline tool, with the bubble line style. This makes a little nicer revision "cloud".
Richard
AC26 (since AC6.0), Win10
Yep, plus using the Mark-Up Tools to track your revisions and the Revision Indicator_NCS 10 lcf
If you are using a PC you might want to consider buying Graphisoft's Change Manager.
This is a absolute powerful tool. Check it out
http://www.graphisoft.com/products/construction/products_and_services/change_manager/
