BUBBLE CORRECTIONS?
HI, I JUST GOT PLANS BACK FROM PLAN CHECK....HOW DO I BUBBLE THE CORRECTIONS WITH THE LINE TOOL, IF THE BUBBLE IS TOO BIG IN SCALE TO THE DRAWING? IS THERE ANOTHER TOOL?
Naddlles
You can change the scale of your bubble line type (or better still, make a duplicate and change that, then assign it) in Options> Element Attributes> Line Types.
HTH
You might also consider using the spline tool, with the bubble line style. This makes a little nicer revision "cloud".
Richard
AC26 (since AC6.0), Win10
Yep, plus using the Mark-Up Tools to track your revisions and the Revision Indicator_NCS 10 lcf
If you are using a PC you might want to consider buying Graphisoft's Change Manager.
This is a absolute powerful tool. Check it out
http://www.graphisoft.com/products/construction/products_and_services/change_manager/
