BUG: Dimension Witness Line Gap
SeaGeoff
Ace
Is anyone experiencing a bug in the witness line gap settings of AC 10? I am seeing these problems:
1. With the Dimension preference / Witness Line Scalability set to Fixed, the value in the Info Box field is off by a factor of 1000 (e.g. you need to enter 2000mm to get a 2mm gap). The value in the settings dialog is correct.
2. The Info Box field reports zero until tabbed into.
3. Tabbing through this field in the Info Box is messed up. It takes four Tabs to move from the field above to the one below.
I am experiencing this with Mac PPC build 817 and 966.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
4 REPLIES 4
Ted Taylor
Geoff,
I am getting same thing. The Info Box does not clean up well either, that is supposed to be 1" in the box.
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
TomWaltz
Yeah, I've been fighting that too. The Settings Menu works, but not the Info Box.
Tom Waltz
SeaGeoff
Ace
Happy and sad to hear it's not just me. I'll send it to US Tech Support. Thanks guys.
Regards,
Geoff Briggs
Da3dalus
Now we have another similar problem plaguing AC11-1210:
http://archicad-talk.graphisoft.com/viewtopic.php?p=126188#126188
Dimensions have always been a bit scary, especially when used in section or elevation. They seem to be very volatile, changing and disappearing for no apparent reason. Very troubling.
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
