[BUG] View doesn't redefine correctly for dimension presets
Running AC26INT4019 on Windows 10.
Naming of view dimension presets is case sensitive - so it is possible to have three different presets named eg TEST, Test and test. However, when changing the preset for an active window using quick options and trying to redefine a view using the view map context menu it sets it to which ever of the three presets that comes first in the list (the first created). Changing through view setting dialog works as expected.
Have you updated to 4034 to see if the issue is fixed?
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.1
macOS Sonoma (14.5)
