2018-09-11 03:09 AM - last edited on 2023-05-19 03:49 PM by Gordana Radonic
2018-09-11 03:01 PM
2018-09-12 03:04 PM
2018-09-13 02:46 PM
SJPHouse wrote:
I’m curious, if you wanted to divide the sheet index into disciplines with headings i.e. Architectural Sheets, Electrical Sheets, etc. would you use the Subsets folder in the tree? I saw it done this way on a blog I found and it seemed effective, just not sure if that’s a work around or what Subset folders were actually intended for?
2018-09-13 03:08 PM
SJPHouse wrote:That is the trick, though there is a Bug in AC22 that will sort them incorrectly. Also for complex projects you might want to split the Indexes by consultant.
Thank you David. For some reason I was worried that referencing a lot of PDF’s would make my file size really large but so far this method works great. I’m curious, if you wanted to divide the sheet index into disciplines with headings i.e. Architectural Sheets, Electrical Sheets, etc. would you use the Subsets folder in the tree? I saw it done this way on a blog I found and it seemed effective, just not sure if that’s a work around or what Subset folders were actually intended for? Thank you.
another Moderator
2018-09-13 04:56 PM
