‎2020-02-19
06:23 PM
‎2025-02-06
12:04 PM
Aruzhan Ilaikova
‎2020-02-19 10:03 PM
‎2020-02-19 11:54 PM
‎2020-02-20 12:32 AM
rob2218 wrote:I thought the best practice is to place the DWG as a drawing on a Worksheet. there you can use as a trace reference. No layers.
Or is there a best practices method for removing DWG polluting layers in one fell swoop?
thanks,
‎2020-02-20 02:06 AM
‎2020-02-20 02:14 AM
‎2020-02-20 02:30 AM
‎2020-02-20 03:53 AM
‎2020-02-20 11:08 AM
Barry wrote:I can't believe I didn't know this after so long on ArchiCAD. Thanks Barry!
You can control the DWG layers if you place it with the drawing tool.
Select the placed drawing and go into the settings.
You may also find the 'layer visibility' in the info box to save opening the settings dialogue - if it is not there you can turn it on in the Work Environment.
‎2020-02-20 07:02 PM
