Best way to show layout options
I'm wondering if there is another way to show interior layout options other then the layers tool. I am reconfiguring a space that wil have a kitchen/bath/ laundry in it and want to show a couple options. I have familiarized myself with the renovation tool and like the way it works. It seems like I should be able to add a filter and show a completely different layout without having to go the trouble of creating special layers. Thanks for any help
1 REPLY 1
You can also use modules to achieve this.
Each of your Design Option would be in a different module. Naturally only those elements would go into each module file that are different in each Design Option.
You should then create a Layer for each Design Option in the project file and when you place for example Option1, make the Option1 layer the master layer of this Hotlinked Module. When you show/hide the its Master Layer, the whole Hotlinked Module is also shown/hidden.
