Brick coursing section/ elevation marker
Evening,
Can anyone point me towards a brick coursing marker that can be associated with walls in section and elevation? Example image attached.
Thanks
1 REPLY 1
The elevation method of the dimension tool will be associative but it will not give you brick coursing (only metric or imperial measurements).
As far as I know there is no way to make a course height object associative to elements in elevation - they have to be manually adjusted.
