Gerry Leonor
Building Material IDs in Labels
A bit of a complicated question for the Hive Mind:
is there a way i can grab the Building Material ID to be called up in a Label?
we've been able to use the same methodology by calling up the Codes in the Surfaces using a Split command in the Properties.
We'd like to use the Property Manager in a similar way to call up the Building Material ID. an added complexity to this is that we'd like to use it in Composite Walls.
https://discord.gg/XGHjyvutt8
1 Solution
Kevin Lee
I see where you are going and yes, best option is to use Archicad label (gdl) not properties.
If you open the label and change the last loop to just 1, it will just give you the outside BMAT. (you can also use reverse option to report the other side as well)
Kevin Lee | Director of Technology | BIM
TZG Architects
ARCHICAD 27 | GDL | Rhino.GH | Solibri | Twinmotion
Certified Graphisoft BIM Manger (2024)
Go to post
10 Replies 10
Kevin Lee
Yes, you can add the components through the skin list label (built-in Archicad)
Unfortunately, Archicad property can't reach the component level of information.  (what you see from the drop-down menu is what you get) thus it has to be done through GDL request process.
TZG Architects
Gerry Leonor
you're right.
so i can't exactly just grab the BM ID of the outside & NOT use the Skin List Label?
I'm more than happy to use Properties. or does that involve abit of GDL / complex Properties scripting?
Kevin Lee
TZG Architects
Ahmed_K
Mentor
Good idea!
It would be great if we can have a number parameter in the interface to select which skin you want to show!
Is it possible ?
Archicad 27
Windows 11 professional
Guru
I made a related wish back in 2018 for composites.
@Josh Verran  made a relate wish back in 2020 for surfaces.
Maybe they will address this by AC35 much like many of the other wishes for things that should be simple... Once they finish trying to integrate features for all the different consultants who would rather use their own dedicated software...
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Ahmed_K
Mentor
AC35 , fixed issues related to SAF and MEP,
maybe AC 56
Archicad 27
Palawat
I have a label that might suit your need. Sorry if it looks like a cheap sell ;
https://www.indigofigs.com/symbol-label-suit/
Archicad 29, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.facebook.com/indigofigs
Gerry Leonor
thank you for the help!
i think this work-around will suit us for the time being, until we get something else.
Nic Tulban
Well done job, Kevin! helps a lot in labelling the 2D Details with the building material description and properties (if extended with a little GDL effort). Thanks a lot!
