archigreen
Can't publish anymore!!! ???
I CAN'T PUBLISH PDF ANYMORE ON AC 13 (NOT TW NOT SOLO)
Does any one have a clue?
Is there a bug on my AC13?
Everything was fine until now.
I really need some help! ASAP
Mac OS X
Version 10.6.4
Processor 3.06 Ghz Intel Core 2 Duo
Memory 4 GB 800 Mhz DDR2 SDRAM
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
4 Replies 4
archigreen
Thank you for the tip.
I have installed the "AC13 Patch for Java Update 1.6"
and now I'm back on track again.
Cheers.
ArchiCAD 26
MacOS Monterey
64 GB
I have downloaded the patch, but it can't find an installed version of ArchiCAD on my machine?!
Help!
Its very much installed, I've been using it all morning!
I cant publish anymore with ArchiCAD 14. Every attempt 'fails'.
It always says that no folder or path is defined.
I used to know exactly how to do this in earlier versions. In AC14, I cant find a button or menu option to allow me to define the path to where documents must be saved.
POSTSCRIPT
Having written that about half an hour ago, i tried the simple idea of using the RIGHT BUTTON on the mouse, and that worked...
Instead of deleting my question, i left it in place in case anyone else had the same problem and needed an answer.
