Can't see anything at 3D View
Hello Friends,
I am experiencing issue with my 3D view.
I am working on this project for more than a month. From yesterday I am having a problem with the 3D view. Nothing is shown in 3D. I performed the primary checking, for example.
1. I checked all layers. They are on. (see Fig-1)
2. Also checked the 3D filter. (See Fig-2)
3. Clicked in the fit to window.
But no way it's getting right. Can you please suggest to solve the issue.
Dear Barry
Superb .................. Just Awesome. It works . I can't believe it.
I don't know how to say thanks for this support. Ur instruction was so easy to follow and worked perfectly.
It made me upset in last few days. I am really happy to get this support.
Love & Respect.
Sincerely
Avi Shiplu
16 REPLIES 16
Check that the renovation filter you are using is not hiding everything.
Dear Barry
I checked every possible way. Even set the new camera to see this but nothing seems working.
Here is a list of things that may cause elements not to be visible in 3D:
https://archicad-talk.graphisoft.com/viewtopic.php?p=235941#p235941
I already checked all the options u suggested. Actually I am working on it for the last 4 days. This item I am really worried about my design completion within the time frame. Can you please check my file with a secure link?
Is it just that one file that has no 3D or is it all files?
I notice in your image of the 3D screen, the axis letters (x, y, z) are there but not the axis lines, which is odd.
They should always be visible as far as I know.
Have you checked the 3d cutplan?
If you put the PLA file on Dropbox or something similar and send me the link in a private message, I may be able to look at it.
Dear Laszlo Nagy
Thanks for your interest to check the file. Here is the link for pln file.
https://drive.google.com/drive/folders/1_EbnJ35TKSpgxco3M9NHeRQdZm8qaTJr?usp=sharing
Avi,
That is not a private link so you may want to remove it.
I had a look at the file and it seems to me you have something a very, very long distance from the origin.
Exactly what it is I haven't had time to explore and find out.
But if you place an all storey marquee around your plan and then view that in 3D you will see the model.
However if you remove the marquee and view all in 3D and zoom to extents, it will zoom so far out it does not respond.
There is something very far away on storey 0 and/or storey 1.
View those in plan and "fit to window" and you will see it zooms very far out.
Al the other storeys seem OK.
Sorry but that is all the time I have to investigate at the moment.
