2021-11-29 10:35 AM
How does one draw simple cavity walls. And once I can figure this out, is there a way to insert windows, doors and openings so that the opening is 'framed', ie. the brickwork around the window or door is actually shown..
2021-12-02 04:03 AM
If you are on AC24 or AC25, you can use the Opening tool to place a vertical Opening into the Wall to create the Cavities. In AC25, Openings can even have a Polygonal shape:
2021-12-02 04:22 AM
@Jensk , can you please clarify.
Do you mean how do you draw a cavity wall (as in multiple skins with an air space between them), or how to add a cavity (void) in a wall as Laszlo has shown you?
