Change Uncut Skin Lines
Hello, I have created a roof made from a composite of different skins. I am aware there is a way to change a roofs uncut line pen, but I what to change the different line pens of specific lines of a single roof ( see attached, I want the line with the red arrow to have a very thick line, the line with the blue arrow to have a medium thickness, and the line with the black arrow to have a thin line). Thanks for your help. ( Attached is also a photo of what I wish to achieve, drawn with lines.)
It appears that what you are wanting to is it for a simple 2D drawing since you don't show any ridge cap on the hips or ridges. When you just want to make the roof outlines bolder you might just as well draw a line.
One way you can get those lines to be bolder is to add some ridge and assign a different pen to it. For example, the Eptar tile roof objects as shown below.
https://www.eptar.hu/cadsupport.php?id=product_block&pID=7&Lang=ENG
It's Free too
Just a tip on how to use the Terran_Topridge (ridge object) -- you adjust the angle to fit the pitch of the hips with the column icon in the pop-up Another good way to do that is with the Morph tool. In 3D window you can put a morph line on the ridges and that way you won't have to draw a line in every view of the roof.
It's Free too
Just a tip on how to use the Terran_Topridge (ridge object) -- you adjust the angle to fit the pitch of the hips with the column icon in the pop-up 2019-07-27_11-13-49.jpg
Thank you Steve, I will download that and give it a try
