2008-02-13
03:06 AM
2023-05-30
01:44 PM
Rubia Torres
2008-02-14 01:51 AM
TomWaltz wrote:In the Organizer, you can of course just drag the layout in question into the publisher set if you like. Works just as well as pushing the button. And gives you control of where in the Publisher set it ends up.
Open up the Organizer with the Layouts on the left and Publisher on the right. Select either the name of the layout book at the top or any subset on the left. You'll see a huge button to create shortcuts at the bottom of the left column. Click that and it creates a "clone" in the Publisher Set.
2008-02-14 01:59 AM
2008-02-14 02:04 AM
Link wrote:Thanks for the clarification, Link!
It really surprises me about the lack of knowledge of this small yet powerful button. There is a major difference between dragging a folder into the Publishing Set than there is using the 'Add Shortcut' button...
2008-02-14 03:47 AM
2008-02-14 03:54 AM
Thomas wrote:Good point - I'll be sure to point that out in future trainings.
The one thing that shows the difference is the small arrow on shortcut folders.
TomWaltz wrote:Ransom Ratcliff? What a privilege. Please send him my regards. Hope all is going well there mate.
It's just proof that no matter how long you use a program, you always have more to learn (that one's a quote my new co-worker, Ransom, uses a lot and I love it!)
2008-02-14 01:57 PM
Link wrote:Yep. Sometimes you get to work with the best and this is really one of those times for me.TomWaltz wrote:Ransom Ratcliff? What a privilege. Please send him my regards. Hope all is going well there mate.
2008-02-28 10:37 PM
Link wrote:From the reference guide:
Dragging a folder, simply makes a copy of that folder *at that instance in time*. That is, if any layouts are later added to that folder later, they will not show up in the Publisher Set.
Adding a shortcut, is like making a clone of that folder, so that if any layouts are later added to that folder, theywillshow up in the Publisher Set.
Another way to create a clone is to drag the folder using Ctrl+ShiftThis works for entire layout sets dragged into an existing Publisher set.
(Windows) or Opt+Cmd (MacOS) within the Navigator/Organizer.
2008-02-29 06:38 AM
2017-10-02 04:51 PM
2017-10-02 05:01 PM
