Column is not centre with Grid system
Inglewood78
I have trouble to  Create Column with Grid system.
I use Design Grid System and use Element at Grid Line by Column. When i place Gris system the column is not in the centre of grid system. How can i fix it?
Please suggest for me please.
Thank you very much.
CosminF
you might want to uncheck the “keep column and/or beam within grid perimeter” box. That should solve it.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
CosminF
Inglewood78
CosminF that is help me a lot.
Thank you so much.
Setup info provided by author
