Complex profiles display in floor plan
Hi. I have problem with display complex profiles in floor plan.
For example: I draw one complex profile beam/strip foundation (e.g. Precast Inverted Tee), but in floor plan that beam is displayed with three lines, nevertheless what Floor Plan and Show Projection combination I choose.
Under the complex beam is "dumb" inverted tee created from two beams and it is displayed correctly.
Does someone have solution for that problem?
Lingwisyer
Guru
If you use a wall instead, your profile will show. The current beam tool does not use a projection of the profile and instead just draws an outline with a toggled centre line hence what you have seen.
Ling.
Lingwisyer
Guru
Ling.
Solved. Thank you!
