2004-01-12
12:04 PM
2023-05-26
12:09 AM
Gordana Radonic
2004-01-12 11:49 PM
2004-01-13 12:40 PM
2004-01-22 03:14 PM
Matthew wrote:He's trying to preserve the layout 'layout' while switching out the drawings. It was extremely easy when we had separate layout files: Save as, drawing usage, link to. Now it's a pain, for example, to make sure the plans stack.
The solution for you is probably to create additional views in ArchiCAD to import to the new layout. I am not clear exactly what you are trying to accomplish so I can't be much more helpful.
2004-01-22 06:18 PM
2004-01-22 07:12 PM
jamesm wrote:I agree. These copies are what we call an "instance". If you know 3DS Max then you know what I'm talking about. An instance is a copy, but any changes to ANY of the copies or the original are changed across the board to all of them. VERY useful sometimes. Wish ArchiCAD made a lot more use of this feature. But in this particular case it's rather annoying. I think there should be an option to copy a layout to create an instance or a copy.Matthew wrote:
I don't see any reason it couldn't work both ways. A copy is a copy, unless re- or unlinked.
2004-01-22 07:25 PM
Matthew wrote:Done.
This belongs in the wish list. Who wants to post it?
2004-01-23 02:22 PM
Matthew wrote:Ah.
Regarding placing identical copies; I do this rather often to collapse a single large scale wall section to fit (with cut lines) vertically on the sheet. (I thought I remebered you doing this also.)
2021-02-02 09:32 AM
2021-02-02 09:49 AM
Carl wrote:
I now this an old thread but, as I see it, the problem still remains (16 years later) .
Does anyone have a workaround?? This bugs me in every project !!
Matthew wrote:
I would like to right click on either the drawing itself or its listing in Navigator to do the relink.
