Dontknow
Create multiple layouts in one pdf
Is het possible to create., directly from ArchiCad, one pdf from multiple layouts?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
5 Replies 5
Eduardo Rolon
Yes.
In Publisher Set Properties select "Create Single File" and in Format select PDF.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Erwin Edel
Or if you have (sub)folder in your publishing set, you can set that folder to 'Merge to one PDF file'.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Dontknow
It worked. Thnx!
ArchiCAD 25.
Or select multiple layouts and Print to PDF
Dontknow
Thnx!
ArchiCAD 25.
