O_De Costa
Custom Sheet Name Reporting on Sheet List
Is there a way to have the Sheet register publish the "custom" name under "Rename items" in the publisher? Or is there an expression/syntax that can be used to generate this type of information?
AC16US - AC29US
Win11 Pro | Build 22631 | Z690 Pro Art WiFi | i9-14900K | 64GB-DDR5 | GeForce RTX3090Ti
Unfortunately no because expressions are available only for Properties, not Layouts. Also, that "Rename items" command is available only in Publisher Sets before publishing them, it is not available in the Layout Book.
The most you can do is to create Layout parameters in the Layout Info Scheme panel of the Layout Book Settings Dialog, and then you can schedule those fields in Sheet Indexes.
