2026-06-04 06:39 PM
Hello,
I am an archicad user from greece and would llike to make a custom label for windows. I have tried but can't seem to quite get it.
What I am trying to do is make a frame which will have the window id, the width on the left and on the right the sill level from the concrete slab of the relevant concrete floor slab and header. This is how we are supposed to do them in greece. I can do it with autotext but i need to click the window to obtain each info and then move it to the table. Is there an easier way to do it using labels? I am using archicad 26. (I want to do the same for doors but using a cicle. They will be measured from the top of the flooring). Thank you.
Solved! Go to Solution.
2026-06-05 03:18 AM
The easiest workaround is to zip the object/s.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2026-06-05 03:30 PM
Hi @KorniliaP
You could open and edit the object using GDL or create it from the beginning (this is easier).
