Customize Label
Good day everyone, I'm new to this forum pls bear with me if ever i'm posting at wrong section.
Its been a month since i studied Archicad, indly help how can i make a label like the one seen in the picture?
Thanks in advance.
3 REPLIES 3
David Maudlin
Drofriz:
The answer depends on the Label's use. What will be labeled? Are the upper and lower text derived from the Labeled element or are they independent text?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank You sir David for answering my concern.
The upper and lower text must derived from the Labeled element ID as seen in its properties. I just don't know yet also how to make a custom Label in ArchiCAD.
Thank You.
David Maudlin
Rizford:
You should make sure that any of the Labels that come with ArchiCAD will do what you want. For example in the US version the Object Indicator_NCS Label will display the ID of an element.
The only way to create a custom Label is by writing GDL, which takes some time to learn. If you want to go that route, then I recommend starting with an ArchiCAD Label that is close to what you want so you don't have to script everything, but just modify parts of the scripts.
David
